CaveGimp
- MVW7230HW0
- Maytag
- 1-5 years
My wife called me in because she noticed the washer making a high pitched sound while spinning. Once the load was done I started looking into the machine. The basket spins freely and the agitator can spin separately from the basket. It initially had an error code of F7E3 or F7E4. I first tipped the machine back to verify the the screw on the rotor was tight, which it was. I then went to test the drive system (Test #3) and after running the agitator test F7E9 and F7EA popped up, same when I tried to run the Spin Low Speed test (I cleared codes between tests). Since there was a weird noise when spinning and F7E9 popped up I tried to remove the agitator but the bolt is stuck tight. I sprayed some Free All last night and it is still stuck this morning.
2 questions
1. How do I get the bolt to break loose, besides getting the torch out (its all plastic and a log way down that tube)
2. What else should I be checking, is it worth removing the rotor, clutch, stator to look for damage?
Thank you
2 questions
Thank you
