- MVWB765FC3
- Maytag
- 1-5 years
When you spin my washer tub by hand, there is noticeable friction for a portion of the spin. It always occurs during the same part of the rotation and you can hear something rubbing. Additionally, the washer no longer spins during the wash cycle. It always throws an out of balance error, likely due to the aforementioned friction.
So, I'm trying to remove the tub and diagnose. I've removed the spanner nut but that's as far as I've gotten. There's a toothy looking washer below the spanner nut that looks to have maybe a rubber seal on it's inner diameter, and I'm not sure if that has to be removed or not. Actually, now that I think about it, I'm not sure you have to remove the spanner nut at all to get the tub out. You can move the center shaft independently of the larger threaded diameter that the spanner nut threads to, just a hair, maybe a little less than a 16th of an inch, but when trying to pull the tub out, it doesn't budge. There is what appears to be a shaft seal around the shaft (hard to tell cause it's so dirty) and I wouldn't expect it to be putting up this big of a fight.
Should the tub be coming out at this point or do I need to also remove something from the underside? This is throwing me for a loop since most of the videos I've seen there's a retaining clip you remove and the tub comes right out. Mine had no such clip.
