Maytag Washer MVWB835DW1 Can't access water inlet valve
sparcboy
Texas
MVWB835DW1
Have a Maytag Bravo XL Commercial MVWB835DW1 washer. Cold water inlet ceased to work. I can't remove the lid or the control panel. None of the videos showing releasing clips or sliding a scraper between pieces of the outer body work. Using a flash light the front is secured with small screws. There is no apparent release. Same for the control panel after removing back cover. Appears to be assembled to prevent theft of parts in a commercial setting. Need to replace water inlet.
W11165546 Valve
Here's the video:
