FIXED Maytag Washer MVWB835DW4 error code F7E5 - Shifter Location
tseibring
Sheldon, Illinois, United States
MVWB835DW4
I have a Maytag Bravos XL that is not starting. It's showing a F7E5 code which is a shifter fault. After you push the start button , the wash plate will spin slowly and the light goes from sensing to wash and back to sensing. No water starts and the tub will not spin. My question is where is the shifter and how do I know if it needs replaced. Thanks
It's possibly the slider or clutch that's gone bad when it does that.
But check these first:
• Check shifter connectors.
• Check for clothing or another item wedged between the impeller and the basket that could bind them together.
• Check that the shifter slider moves freely.
Here's the Shift Actuator(also called Slider) for your model(video included in part link):
Shift Actuator W10734521
The shifter coil is the clutch assembly, it has the Orange and White wires going to it.
Here's the clutch(shifter coil) assembly for your model:
W10754448 Clutch
It's also here:
Here's another member that said the new clutch fixed his:
Here's the video to access those parts and replace it:
tseibring
Thanks Jake, I've replaced the clutch and checked to see if the slider parts move freely. After doing this it's still doing the same thing. I remember it making that loud click when you first start it and it's not doing that. Could it be the stator? One thing I forgot to mention is when I plug the washer in , it has a little spark coming from the plugin. Is that a sign of a bad ground or wiring? I've checked all connections and have found nothing.
Don't worry about that, I see that happen too on these models, its normal.
F7E5 Fault is displayed when the main control determines the shifter is not engaging the basket for spin or disengaging it for wash.
• See TEST #3a: Drive System – Shifter, page 15.
Here's the data sheet for your model: https://drive.google.com/file/d/1ofJhcJP0-NeEEDgLJfYm5JxLaMFvdtQm/view?usp=sharing
Do all those steps it mentions to do, you will need to just be patient and take your time with this one. I have not run across this F7E5 issue on these models as of yet, so just follow what it tells you to do.
tseibring
I found the problem, I pulled the slider all the way out which was a little hard. I found out the magnet around it was cocked and causing it not to go in and out freely. This one is fixed after I replaced it with a new one.
