FIXED Maytag Washer MVWX700XW2 Spin and Drain Issues
Zaulism
Arkansas
MVWX700XW2
We've been having issues with our washer leaving clothes wet. It has been happening seldomly, but increasing more and more. The past few days, it leaves clothes wet more often than not.
I set the washer to drain and spin, with the clothes still wet.
The washer went through the check fine, then sensed, seemingly fine.
I heard the drain kick on, and it drained water.
The washer then started to spin.
One time I observed, the washer spun slowly, the second time the washer kicked a bit higher in speed, but stopped. Neither time did the drum become unbalanced.
The washer kicked on the drain. There was 11 minutes left on the timer at this point.
After this, the washer lid unlocked.
After a bit, the lid locked again, the washer drained, the lid unlocked. I believe the timer was at 6 minutes.
I don't remember if the lid locked again, but after a bit, the end of cycle jingle played.
I checked the belt under the washer, and pulleys, it all appeared good. I suspect it isn't the lid lock, but let me know. What can I do next to troubleshoot, or is this enough information to diagnose?
It sounds like possibly the hub or shift actuator is bad.
Here's the hub for your model:
W10528947 Hub
Here's a video to access/replace it:
--->Look at these photos below of the hub teeth grinded down to smooth. It should NOT be grinded down to smooth.
Zaulism
Arkansas
I believe the teeth on my hub are fine. Does that mean my shift actuator is bad, or is there somehow i can test it?
I see in your photo some of the hub teeth are missing.
I'd replace that first.
Here's the shift actuator for your model:
WPW10006355 Shift Actuator
Video included in part link to access/replace it.
I'm attaching the tech. data sheet below, you can do--->TEST #3a: Drive System – Shifter
To see if the shift actuator is good or not.
  • W10468342 - Rev C.pdf
Zaulism
Arkansas
I bought the part, and installed it. After testing, all appeared to be good. The washer is spinning the clothes good.
I'm not sure if me taking the console off, or the part replacement, or something else, but now the washer is either restarting itself or taking very long to complete loads.
At the end of the load, the washer is displaying Le error. If the washer has 60 minutes left, and we set a second timer for 60 minutes and check, it has 30 minutes left. I'm not sure if this is 30 minutes of a restarted cycle, or if it is still the same cycle.
I know if we leave it alone for 2-3 hours, it'll still be going when I go check on it. What do I do next?
Zaulism
Arkansas
I don't see that I can edit my previous post:
We had it set on Whites, and the dial is still on Whites, but the light indicator for the dial is now on Normal (2 slots over). I'm not sure if it went from Whites -> Heavy -> Normal. I'll try to figure out if that's what is going on (White Cycle -> Le Error -> Start next clockwise cycle -> Repeat
After some googling, i'm thinking I maybe have continuous test cycle turned on. I'm going to disable, then report back if all is good.
Zaulism
Arkansas
Ok, That fixed the problem. All is good.
My shifter was bad. Replacing it fixed that.
While diagnosing, I had enabled continuous test mode. After disabling, all is good. Topic can be closed.
Excellent, glad to hear the new shift actuator fixed it.(y)
