Jworks
- MBF2255KEW
- Maytag
- More than 10 years
I have Maytag MBF2255KEW refrigerator with freezer on the bottom. Its worked flawlessly since 2006. Suddenly the water tube going in to the icemaker freezes up. It quit making ice. I read about thawing it out and I did. It started making ice again and did so for a couple of days. Now it quit making ice again and I imagine the water inlet tube is iced up again. I tested the temp in the freezer with an outside thermometer (digital). It went down to -1, then 0. From 0 it went up to 4, then went as low as -5.
As I type its slowly changing back upward. Maybe this is normal. The manual says the freezer should be 0 to 2F. It also says you can adjust the level up or down but not more than one number in a 24 hr period. Also says changing either Control will have some affect on the temp of the other compartment.
The freezer temp control is a digital readout with up/down buttons. Frig is on 5, freezer is on 6. I don't know for sure if its always been on 6 or if we possibly bumped one or the other. I have no way of testing the water pressure but it "seems" fine to me. The icemaker makes those half-moon type ice cubes. About 4 months ago our plumber replaced the copper tubing water line because it was spewing a fine mist of water on the wall so he put on a flexible hose that looks like mesh, and is larger than the old copper tubing he took off. This worked fine, no issues.
Now suddenly I'm having this freezing issue in the tube. I don't think this has anything to do with the freezing issue; but the refrig door gasket needs replacing and water drops form on the inside of the refrig. The bottom of that gasket is cracked. I just havent replaced it. I need some help before I have to call out someone and pay out the $$$.
