MCO165UW Magic Chef microwave won't heat
davgard
Massachusetts
MCO165UW
Magic Chef
My Magic Chef microwave won't heat. it was working fine yesterday and now it runs but doesn't heat usually i can hear when it cycles during the timed cycle. now it just has a steady sound. any ideas?
model: MCO165UW
usually you can hear when the HV side kicks in and when it cycles on and off. Most of the time the problem is a faulty door switch. Check the door switches for continuity with a meter by opening and closing the door.
davgard
Massachusetts
since first writing here, i learned that the microwave was run empty, it was being used to time something else and mistakenly the cook timer was used instead of the countdown timer. it seems maybe this is the cause, with that being said where do i go now? i will still look at the door switch just in case.
