MCWBC77DZC Magic chef dual zone beverage center fan not working
Cjaws
Suffolk ny
MCWBC77DZC
Magic Chef
Looking for help w my dual zone mini fridge. Bottom fan is not working. I switched the wires, then the top went out, so I assumed easy fix, that I needed a new fan. Spoke w magic chef cust Sven who confirmed and said I would also need to replace board as well. NG...same problem, I then ordered the wire harness, that goes from board to both fans figuring that was problem. NG...same problem. It seems to be a fairly simple product, not much to it in way of mechanics/electronics. And FYI when you plug in fridge, BOTH FANS turn on for a few seconds, then stop. Few seconds later compressor goes on (seems that’s what it’s programmed to do) and that’s when only the top fan (zone) works. Any input would be greatly appreciated
jsquared90
Valparaiso, Indiana USA
I have the same exact problem and symptoms. I have not replaced the main board yet like you did. I confirmed both fans work fine by connecting 12V power direct to them. Did you ever find out the solution?
