- MDB4949SD
- Maytag
- Less than 1 year
I recently purchased a Maytag MDB4949SD which I saw was consistently rated one of the best low-cost home dishwashers. I know it features a grinder. It worked great for a few weeks and now it's not at all. Some times I'm pretty sure it's not even spraying since the detergent pod will be at the bottom of the tub.
It has adequate rinse aid and I'm using Cascade Platinum. I run the hot water before running the dishwasher.
I can't find any information on dismantling the bottom to clean it out. Does someone have instructions on how to get to the filters / pump and clean it out?
I was able to take off the spray arm and pop up, but only partly, and remove a weird plastic filter-looking thing that was full of gunk and pet hair.
It cleaned well for about two cycles after that and then started not cleaning again.
Any ideas?
Any ideas?
