cmofknox
- MDB6769AWB1
- Maytag
- 6-10 years
My Maytag top control dishwasher is approx 9 years old. Still runs fine, but I suspect either the circuit board or membrane switch (on the top of the door) is on the fritz. Most of the buttons don't respond, and honestly haven't for a few years now. I've nursed it along.
I'm now to the point I turn it off at the breaker and turn the power back on to run it. If I leave the power off for only a minute or so, that doesn't seem to clear it.
When I turn the power back on, I can run and complete a normal cycle with dry heat and nothing else. No other options work. If I open the door and add an item, I have to start completely over because the Start/Resume button will only blink and no longer 'resumes.' At it's worse some times the lights for each cycle on the membrane panel light and blink on and off like a Christmas tree.
I saw a few Youtube videos where people have fixed Whirlpool dishwashers where the Molex ribbon leads between the control and circuit board go bad or are damaged by moisture. I can find no indication of that after taking it apart. NOTE: This is a Whirlpool design/made Maytag.
Because of all this I still suspect it's the membrane switch/top control, which is really part of the plastic top door assembly. I've had the door apart, so I'm not afraid to replace it.
Thoughts...
Thoughts...
