MDB7749SBM3 Maytag Dishwasher no lights
dad004
Camden
MDB7749SBM3
I delayed the start of the dishwasher to run over night. The next morning, there was some standing water, and no power, no lights. Could this be caused by a faulty high limit thermostat? If not, what are some other possibilities?
Let's go back to 2017, when you posted this here:
What did you find about the drain pump? What fixed it then?
dad004
Camden
The drain pump. However, this time the control panel is completely out. The last time, we had lights.
Got it! Thanks!
Lets first check the door switch. Check the resistance of the door switch with a multimeter. Should be less than one ohm. High ohms=bad switch.
Here's the door latch switch assembly for your model you can order if yours is bad:
Door Latch WPW10653840
There is a video in the door latch switch part link that shows you how to remove it and replace it.
dad004
Camden
I was going to check that, but I found this: This was the control panel. That didn't look good to me. I replaced that.
What is the piece that the white connector goes to? It's also got burn marks on it.
What in the world could have caused this? I have read where others have had issues with the control panel. Is this a bad model?
Yup, you found the problem.
Here's the control panel for your model you can order:
W10811169 Panel-Cntl
dad004
Camden
I have replaced that, but the piece that the white cable connects to is also burnt. What is that?
Got it!
That's the wire harness, you will need to order and replace that too if its burnt as well.
Here it is for your model:
Wire Harness
dad004
Camden
The next part in the chain. The gray box that the wire harness plugs into. It sits behind the front cover.
dad004
Camden
I think so. I replaced just the control panel with no luck. The control board has burn marks on it. Have you ever seen both burnt?
Nope, that's the first I've seen both get burnt in my 33 year appliance repair career.
dad004
Camden
Would the control board be the next thing to try? Or is there something else I should check?
Yes, replace the control board too, sorry I forgot to mention that in my last post.
