MDB8959SFZ4 Control panel buttons sinking
howaboutme
Fairfax, VA
MDB8959SFZ4
Hi all,
New here and hope you all can help. I have a less than 1 year old Maytag mdb8959sfz4 dishwasher. Works great except the control panels buttons are starting to sink down into the door panel. However, not the entire row, just the right side where the start button is. It's gotten to a point where we have to use a pen to push down to get the washer to start.
Does anyone know what the deal is? Since the washer works great, I can assume the electronics are fine and that for some reason the panel is not against the top edge. How do I fix this? I see screws (do I need a special driver?) for the entire door panel in the back (inside) but not specifically for the control panel areas. Pic below.
(Asking since I don't believe this is covered under the warranty.)
Any help would be appreciated.
Call for warranty service
Whatever is holding that switch mechanism may have broken on one side? It should be under warranty except if it was the result of abuse.
I suggest you call for warranty service before trying to tamper with it yourself. Make sure you have the exact date of sale when you call.
LINK > Appliance411: Requesting Servuce
JMO
howaboutme
Fairfax, VA
Thanks for your reply. I double checked, it's out of the 1st year warranty. I was mistaken w/ my initial post.
Still something I should pay someone for?
If it's out of warranty you can try looking into it yourself. I don't know what the cause is, maybe that switch's mounting is damaged or has just come out of place? A lot of these things just snap together. The cause may be apparent once you get to it. It may require a T-15 Torx screwdriver or bit.
There is video instructions on how to access the door latch used on your model at the following link. It help you to access the other components inside the door.
LINK > Door Latch WPW10653840 and Repair Help Videos
howaboutme
Fairfax, VA
Thank you very much! That video is helpful. That was the first thing I tried to look for but didn't find a video on this particular model but now see that it is similar to other models. I appreciate the help. Now..need to go get a new screwdriver..
djcarter75
TN
I have the same issue. I took the front panel off with a T15 screwdriver bit and lifted the front panel off. Then removed the one screw on the inside that holds the top controls. I removed the ribbon cable wire from the front and removed the push button assembly. The tabs that hold the assembly are broken on the right side where the start button is allowing the board to push down and not click. Where can I find this board holder at? I have scoured the net and cant find any numbers for it.
djcarter75
TN
Thank you for the reply. I was able to glue the board on the side that had the broken bracket so the button would actual press and click when engaging the board. The bad thing is the board start button does not function which is why it was probably pressed hard to break the bracket to begin with. Luckily I found my receipt from Lowes and I bought the extended warranty that runs out in December.
It is a Maytag MDB8959SFZ4 dishwasher as the original poster. Thanks again.
The parts list doesn't show that holder separately. It looks like the whole control panel might have to be replaced if it is needed.
One bonus is the control panel assembly (# W10910624) is listed as cheaper ($100-$125) as compared to just the switch unit (# W10898450) at $170-$190 even though the assembly shows to include the switch unit.
Even Better!
