MikeS1656
- MDB8959SFZ4
- Maytag
- 1-5 years
Hello. We recently started having an issue with our Maytag MDB8959SFZ4 dishwasher.
The unit is about 4 years old and has been working fine until recently.
The other night we had a minor power surge (lights flickered briefly, no clocks reset though) the next Day we tried to run the dishwasher but it appeared “dead” no leds, no readout on the lcd screen, nothing.
I thought it got fried from the power surge and started doing some research, I figured out how to test the control panel (disconnect control panel, restore power to machine, close door. If the drain pump runs, which it did, that indicates a bad control panel) I took out the control panel and noticed that the rubber gaskets around the buttons were deteriorated and there was some corrosion on the circuit board.
I ordered a new control panel and installed it. Everything looked good, I restored power to the machine and started a cycle, but it only ran for a couple minutes before stopping. However the timer continued to run as if the cycle was in progress but the machine wasn’t doing anything… I’ve tried running a diagnostic cycle and resetting the machine. I don’t know what to try next…
Any suggestions? Thanks!
Mike
Mike
