Bingo!
I found a service bulletin that came out in Nov. 2020 about that metal piece in the drain pump. It says to remove it and it will still drain fine without it.
It says it can be ordered once it becomes available:
Mp-sp, 120/60, drain chopper, askoll W11497943 / AP6994646 made by Whirlpool
click.linksynergy.com
FAQ#1:
Should/ Can I leave the unit operable, if the replacement is not available at the time of service?
*This Maytag dishwasher has a dual filtration system.
In order to provide the best customer experience, it may be possible to leave the customer with a working dishwasher under the following conditions:
● Remove the debris in the drain line and pump housing, and in some cases the Rotating Inlet Filter assembly.
The drain pump can be operated without the metal blade because the dishwasher will continue operating with the primary filtration system.
● Replace the drain pump when one is available.
● In most cases, the drain pump thermal protection circuit will not be damaged by a stuck drain.
FAQ#2:
How/ what should I communicate to the customer if the replacement part is not available at the time of service?
Answer: (If the unit was found to be operable, communicate) “The unit is operable until the follow up service call. With the current state of the pandemic there may be a delay in replacement parts.”
