- MDB8969SDM0
- Maytag
- 1-5 years
Our 4 year old dishwasher cleans dishes great, but it has had way too many issues for an $800 machine. Recently, it just continues to run for up to 8 hours (or more because I stop it). The timer counts down ever so slowly but sometimes doesn't even change. There is water in it, and it is hot and steamy and the dishes seem clean (which I would hope after 8 hours in the dishwasher). I can run a rinse cycle which works fine. The unit seems to drain fine.
I ran the diagnostic mode and get f8e2 which according to the manual is pump related. Following the diagnostic directions, I checked the drain pump winding resistance and get 22 ohm which is in the 15 to 25 ohm acceptable range. However, in looking at the drain motor it is only 40W whereas the diagrams say it should be 100W. Not sure what to make of this because online states 40W also. Also checked for obstructions in the drain, all clear. I cleaned all of the plug contacts and used deoxit.
Any other ideas would be helpful. I dont like manning the dishwasher all the time...
Added complete model number
