MDBH970AWW Maytag Quiet series 300 Dishwasher touch panel won't light up
Jdyer61
Aragon,Ga
MDBH970AWW
I purchased the dishwasher Model# MDBH970AWW used $45, told it run,just wanted to upgrade, got it hooked up it ran alright, but noticed the plastic on the touch panel was broken at the latch area, thought no big deal,took it off and sanded it , epoxy it and my only mistake is the flex cable came lose during repair,thought I'd just connect it back,well got it together now no lights or nothing, used my meter to check for voltage ,dishwasher is getting voltage, but still no lights. I looked everywhere on the unit but no service paper work. When i took it apart,I noticed the latch was broken,so I purchased a new latch with handle , can someone please provide the link to the service paper on this model for me? This dishwasher is for my step son, I just finished repairing my wife's Bosch dishwasher, it's only 4 yrs old warranty out just as it went out,replaced new control panel, replaced circulation heat pump had leak, water inlet valve, but it's running like new dishwasher again,wife's happy and didn't have to go out and spend another $1400. any way sorry to get off subject..
Here you go:
  • MDBH970 MDBH950 Tech Sheet.pdf
Jdyer61
Aragon,Ga
Rick, to check the continuity for touch switches, would i need to put my probes on say pin1 and other probe on pin13 just example and press corresponding switch to see it it has continuity ? not looking at diagram at this time just how to check it. thanks in advance
Jdyer61
Aragon,Ga
Thanks, one other question which is J1 on the control panel? I'll take pics of the control circuit board and attach it here in a few. again thank you for the help
Jdyer61
Aragon,Ga
never mind I found it. on the J1 it has 1 2 17 18 , far as the pins which order is the pins in far as left to right up down and so on?
Jdyer61
Aragon,Ga
does it go top row 2,4,6,8,10,12,14,16,18 and bottom row would be odd numbers 1,3,5,7,9,11,13,15,17 ? on the J1 pins
Jdyer61
Aragon,Ga
Thank you, that helps me a lot... again you are a big major support here.. i appreciate you taking the time. I'm wanting to learn how to trouble shoot the dishwasher not just a parts changer, again thank you for taking your time with me, have a blessed day..
