Al2000
- MDE4916AYA
- Maytag
- More than 10 years
Hello, I have a Maytag MDE4916AYA electric dryer about 15-20 years old that is in wonderful condition, except for that over the past 10 years, i've always felt that the DELICATES temp setting had no different temperature than the REGULAR temp setting. I never really did anything about it, because i was thinking that perhaps it was just me and it is too hard to determine the difference in temperature by just feeling the clothes. However, this past week when i slid out the dryer to clean the vents,etc due to it getting hotter than I'ld like, I decided to take the disconnect by ducting from the back of it and run some temperature measurements for each heat setting. What i found blew my mind.
The readings i got for the 3 temp settings taken just inside the air exhaust outlet were as follows:
REGULAR 162 degrees
MEDIUM 157 degrees
DELICATE 152 degrees
Each time they hit the temperature stated above, i heard the "click" and the heater element shut off until the temp reached about 121 degrees, then came back on and stayed on until it reached the temperatures stated above.
Surely there has to be more than 10 degrees difference between the REGULAR and DELICATE temp settings. After doing some reading, it seems that a reading of 125 - 135 degrees would be a more accurate reading for the DELICATE cycle.
So I went online and ordered a new OEM cycling thermostat and a temperature switch. I received them the other day and installed them. NO DIFFERENCE WHATSOVER. Actually, the temperature measurements each went up by 1 degrees, but that was it!!! I tried to look at the circuit diagram/schematic to see what other factors could be influencing the dryer having incorrect heater element shut off levels, but i just don't see anything else that could be affecting it.
Any advice for this situation, as i hate to buy a new dryer when mine is working perfect except that the temp ranges are all high. Thanks.
REGULAR 162 degrees
MEDIUM 157 degrees
