ME18H704SFS: No power
Cold Apophis
Las Vegas
ME18H704SFS
Samsung
My Microwave has died. Outlet power is good, but I've got no lights and no activity. Upon inspection, noticed charring on the #21 Thermostat, (KSD 140LC) and couldn't remove the left wire due to the charring. Had to re-terminate wires and replaced the thermostat with a DE47-20034A. I've plugged it back in; still no power. both bottom thermostats test open, top thermostat tests closed. Both fuses that were visible to me tested closed as well.... not sure where to go next. Any help would be appreciated!
