ApplianceBCS
- MED302JS/04
- Thermador
- 6-10 years
Hello I own a appliance repair business in Texas and want to see about thoughts on problem with this oven. It is a Thermador Model# MED302JS/04 double oven electric. Unit has the needed 240v coming into the unit. There is no display at all and no functionality when any buttons are pressed. The oven light comes on when the door is open. There are 3 boards in the unit which are the Power Board / Relay Board/ and User interface. The Power board which is P/N# 00663802 has 3 wires One Black line (120v) / Neutral and Ground. Also there is one series plug that have a couple coming off of it and when measured it is around 9V DC. That 9V DC line goes to the Relay Board. Measuring the Voltage going to the display board is 9V DC. I will also note that the Power Board has a mild chatter coming from the transformer on this board. When unplugging the wire from the Power Board to the Relay Board this chatter stops. This leads me to believe that the Relay Board is the culprit. Any thoughts on what might be going on here!?? The Relay Board which I am referring to is P/N# 12022214
