MED9700SQ0 Maytag Dryer Temperature Control Problem
Rackets
SE CT
MED9700SQ0
Hi All,
I did a search and found nothing directly pertaining to this malfunction.
I'm new here, and grateful for any help that can be provided. I have the above listed dryer.
It's worked quite well for a while now, but only recently it exhibited this issue:
I cannot control the temperature when on the timed cycle. It defaults to "high"
or "medium," depending on the timed setting. The auto settings default to the normal
temperatures, but cannot be adjusted manually.
The temps are high, medium, low, very low and air only.
It's a toggle of sorts; the button is pushed repeatedly to adjust temperature.
Does anyone have any ideas? If I can avoid the purchase of a new motherboard that would be
super. Is there a separate Temp Control module/controller?
Better still, would anyone happed to have a Service Manual for this appliance?
Anything would be appreciated.
The problem is the user interface control board.
Here it is for your model, unfortunately Its No Longer Available:
WP8558455
