FIXED MEDB850YW2 Maytag Bravos xl - Dryer starts and runs 5 to 10 minutes
Forkman27
Tn
MEDB850YW2
Dryer starts and runs about 5 to 10 minutes. drum stops turning. No error codes. Display continues to count down. After a while the dryer will kick back on. Heating element ohmed at 11 ohms. I replaced Thermostats on heat tube and thermistor. A couple days before this happened we had severe storms and lost power. Voltage input is correct. Thinking issue is with electronic control board,not sure.
Thanks.
Yes, that may have been what happened. Unplug your dryer and open the control panel, then remove that control board and look closely at your control board and see if you notice any burnt spots on it.
WPW10432257 Electronic Control Board
Forkman27
Tn
Replacing control board repaired issue. Would have been nice if my original google search for a repair manual for this machine would have told me to check under the console.
Glad to hear the new control board fixed it.:)
