Melted plastic cover inside microwave - Maytag YMMV4205DS0
kg_ca
Toronto
YMMV4205D
Can someone tell me what is this melted part in the microwave Maytag YMMV4205DS0? I would like to replace this. Also, how to avoid this in future?
OK, it looks like the wave guide cover. Any food that gets on it will heat up in that spot or if the stirrer fan blade touches it the heat will focus on that spot. When you remove it make sure the stirrer fan isn't loose. Keep the cover clean.
