FIXED MER5755QAW Maytag Oven will not heat up past 200 degrees
fernram
North Port, FL
MER5755QAW
Oven takes over 40min to get to 200 degrees and will not get any hotter past that.
fernram
North Port, FL
Just checked my mother-in-law's oven today per your suggestion. The oven only has a top element - assuming its a dual bake/broil element. When I set the oven to broil on HI - the element got hot right away. However, when I set the oven to bake at 400 degrees - the element lost its heat and did not feel as hot as it was on the broil setting and after 20min the oven only reached 185 degrees. Does the element need to be replaced?
Thoughts???
fernram
North Port, FL
Jeff,
It appears that the hidden lower element was not heating so I ordered the WPW10276482 per your suggestion and I just recieved it. The element came with no instructions. Where can I get a detailed and graphic instructions on replacing the bake element - especially since it hidden. How do I remove the metal panel to access the hidden bake element?
A copy from the manual:
Bake Element
1. Turn off power to unit.
2. Remove screws securing oven bottom cover.
3. Raise the back of the bake element cover and slide cover back to release the front edge of cover and lift out of oven cavity.
4. Remove screws securing bake element to rear of oven wall.
3. Pull element forward to allow disconnection of terminals on each element leg.
4. Reverse procedure to reinstall bake element.
fernram
North Port, FL
Thanks Jeff.
I replaced the bake element this afternoon and the oven is back to heating normally.
Thanks again for all your help. I will definitely recommend The Appliance Blog to anyone.
Would also like to replace the oven racks. Are those avalable?
