MER6751AAW Maytag Dual Oven Electric Range Bottom Bake Element Broken
chaz24
Massachusetts
MER6751AAW
Appreciate suggestions regarding the following observations.
I believe I need to buy a bottom baking element. I see a 2" segment has broken off.
I believe the lower broiler element may be okay. It registered 520 degrees F using an oven thermometer after 15 minutes on the broiler high setting.
The upper broiler element registered 150 degrees F using an oven thermometer after 15 minutes on the broiler high setting.
The upper baking element registers a reading of 335 degrees F with the control set to 350. My wife believes that it gets hotter in the rear of the oven than in the front.
Thank you,
Yes, that is the part you need if you clearly see its broken. You can always ohm test it too.
To ohm test it, you'll need a multimeter to ohm test at your bottom bake element terminals in the back of your range. You'll need to pull the range out from the wall and take the back access panel off, unplug your range first before accessing and ohm testing it! Also remove the 2 wires first before ohm testing it.
Here's the lower oven bake element for your model you can order:
Bake Element WP7406P428-60
chaz24
Massachusetts
As I mentioned I saw there was a break in the element. A 2" section had broken off, both ends, and was lying on the floor of the oven. I have ordered the element you had pictured.
I realize you should unplug the range before changing the element. Would shutting off the breaker accomplish the same thing? The range is on its own circuit.
Thank you
Yes Correct, shut the breaker OFF to it in your home breaker box.
