FIXED MER6765BAW Maytag Gemini Range will not heat
Wis53189
Wisconsin
MER6765BAW
Hello,
I have a Maytag gemini model number mer6765baw. While using it tonight all the heating functions stopped. Both ovens and the stove top. The display and control buttons all appear to work. When I set the controls to begin heating the ovens or stovetop it even makes the normal sounds it always has. But nothing heats.
I unplugged it for about 10 hoping to reset it but no change. Any ideas other than a new control panel??
*Sounds* like you might only have 1/2 power to the range.
1 of the 2 house ranges fuses lets go.
1/2 of the ranges breaker let go.
Power cord burnt ( inside or at the receptical plug ).
T block inside the range burnt.
Terminal Block
Red to black 220-240 volts AC. Red or black to white 110-120 volts AC.
Wis53189
Wisconsin
This stove was also having issues with 2 buttons on the control panel not working. Since the replacement of the terminal block and cord, all buttons are working like new. Maybe just something else to think if when a button fails.
