FIXED MER6872BAW Diagnostic test mode
frabreeze
Montana
MER6872BAW
Good morning, I'm working on a Maytag glass top/double oven. The two oven portions will not turn on to heat, elements check out good but nothing happens when the buttons are pushed on the control board.
I don't have the owners manual for this so wondering how to put on diagnostic test mode? I took the ECM out and apart and can't see any burnt spots on the boards, is there anything else to check? Thanks
So none of the button respond when you press them?
If that's the case then your clock oven control board is bad, and Its No Longer Available: WP5701M406-60 Clk/ovrly Kit, Blk
frabreeze
Montana
Thanks for your help Jake, got it up and cooking again, I believe the owner had inadvertently put it into control lock, with out the manual that you sent me I would of never figured it out. Thanks again.
Glad to hear that's all it was.
bigbuck sent the manual.:)
Thanks bigbuck!
