FIXED MEW5527DDS10 Maytag oven touchpad not working correctly
Thebigad
Georgia
MEW5527DDS10
I tried to use the oven and the touchpad won't work properly. No error code. Here are the keys that respond:
Clean. But I can't actually start the clean function.
Cancel.
Timer. But only with the 4, 5, 6 keys.
4, but nothing happens
5, but nothing happens
6, but nothing happens
Favorite, but nothing happens.
I tried holding down the Cancel key for five seconds.
I tried holding down the Cancel and Clock key for five seconds.
I tried resetting the fuse breaker.
This happened once before after a power outage. Holding some keys I can't remember now fixed it then. No key combination worked this time, however.
What's going on?
I'd be trying a new key panal...
picUnavailable417.jpg Touchpad and Control Panel
W1104061-00004.jpg #1.
Thebigad
Georgia
It works again.
So....I left the breaker off all night. Turned it on this morning. It is working flawlessly again.
Any ideas what's going on here? I don't want to replace the touchpad if I don't have to...
Thebigad
Georgia
It did come back to haunt me! Lately, turning it on and off at the breaker doesn't really help. When I do get it "reset" and on, I can set it to bake at 350 for example. But then some functions may not work, like turning off the light. Or if I want to switch from baking to broiler, I can't. The touchpad becomes unresponsive again.
No error message shown.
But the oven works fine as far as heating and cooling down. So, do I need to replace the control panel or the board behind it? Thanks.
Thebigad
Georgia
The touchpad worked great. And then a few months later, the oven has no heat. Touchpad still seems to work fine. I had a repair tech come by and he said I have a bad board. I can't seem to find the board for this particular model - any advice?
Thanks.
Drewcobb51
Kentucky
I have this identical problem. I can’t find a control board that is not black. We need stainless steel. Has anyone had success finding this? Thanks.
