MFI2269VEM6 Panel goes black. Cooling stops.
pamie82
Alberta, Canada
MFI2269VEM6
Discovered the panel on the front of the fridge was black and wasn't cooling. Checked connections and nothing appears loose. Reset breaker a couple of times, but did not make a difference.
Waited a day and panel turned back on, but now will flash (like it's losing power) intermittently.
Thinking it might be the main control board, but it's going to cost me $350 for a new board in Canada. Worth calling in someone to diagnose the problem? Or is the HV board the most likely cause?
Check for 12 VDC across J6-1 to J6-2 on the main control board. Check for 12 VDC across J1-1 to J1-3 on the dispenser board.
