aggiediesel
- MFI2568AEB
- Maytag
- 6-10 years
I searched and saw that this question has been asked once before but there was no resolution to it so I'm going to ask again to see if I can figure out an answer.
I have an MFI2568AEB Maytag French Door Fridge Serial 10056129JP. A few months ago the button to switch btwn Ice and Water became slow to respond. Sometimes it would switch and sometimes it wouldn't respond to touch for a few days and then it would start working again. Now it seems that it won't switch at all and when I tried some of the other buttons like "max cool" or "vacation mode" there is no response. Everything seems to work fine in the fridge otherwise. It still makes ice, puts out water, freezes, cools, issues temp/door open alarms etc. I just can't switch btwn the two functions or initiate the other modes. I have not tried putting it into programming mode or performing any service tests listed in the manual b/c they didn't seem to correspond to my problem.
Is this the control board on the front failing, or the touch pad, or the main control board? A couple of years ago, after a power surge, I had to replace the main power control board on the back of the fridge, and I did so with an OEM Maytag/Amana part.
Are there any diagnostics that can be done to actually figure out what the problem is before I throw another couple hundred bucks at it? I am electrically competent and I have no trouble performing pin tests if this is necessary to figure it out.
Thanks for any help.
