MFI2568AES Will not accept the refrig code
Peaches205
Mississippi
MFI2568AES
Please help! I have a Maytag Refrigerator MFI2568AES and I bought a electronic control board and the board will not accept the refrig code location in the refrig. My serial number is 10336041JP. Can you please help me? Thanks
The control board should of come with Programming instructions, look in the box, look under all the bottom flaps to see if its under there.:)
W10890094 Cntrl-Elec
Program code is located on the serial plate
Press and hold the Door Alarm keypad.
Press and hold the Freezer Temperature Down keypad.
Release the door alarm keypad and wait 3 seconds.
The control will display PE to indicate the programming mode.
Press the Freezer Temperature Down once more.
The control will display the current Program Code. This should be the same as the program code on the serial plate. If the code is correct, press the Door Alarm keypad for three seconds to exit.
Press the Refrigerator Temperature Up keypad or Refrigerator Temperature down key pad to change the digit value. The decimal point indicates the selected digit. Press the Freezer Temperature Up keypad to select the next digit.
Once the correct program has been entered, press and hold the Freezer Temperature Down keypad until the program code begins flashing indicating it’s been saved. Exit the programming mode by pressing any key.
