MFI2569VEM4 Maytag fridge - no display after loss of power
Russell Reid
Virginia
MFI2569VEM4
i have a maytag model MFI2569VEM4 -lost power -after power restore display was on/off-until it was mostly off. i push keys and whole display lights up. I replaced main control board- same symptoms-no display unless keys are pushed.
I traced out 120 volts ac to main and 13 volts dc from main to dispenser-replaced dispenser and key pad-still same issue- cant program- refrigerator not cooling but lights are on when u open door and up and down buttons open and close dispenser-about all it does- do you think i received a bad main control board or do i have other issues?
I have invested about 400 dollars into this and one company won't let me send dispenser board back- should i order another main control board.. i replaced main board with exact match w1031269bB most sites say use wpw10312695???
Russell Reid
Virginia
I understand that but i got the exact board that was in it and that's not the number. I know that is the updated number- what i am asking since they sent me the old version which is what is in it now-could that still be my problem??
I received pn w10312695b which is exact match for what i took out. and had same problems after i swapped it.
All the voltage checks out with either board and dispenser board and keypad didn't fix it either so am i back to ordering a updated control board because they sent me a bad one or is it something else that could be involved?? Thanks!
I don't know what the difference is between the boards. If the voltage is 12V at the dispenser board and the board is not working I got to think the board is the problem. Check the wires between the two boards for continuity.
Russell Reid
Virginia
continuity is good. dispenser and keypad already replaced-same results-control replaced-same results -all voltages good. got be something else involved??
Who is they?
How much did you pay for the main control board?
Then obviously your board is defective.
This board retails at $337 so if you buy if from Ricks link to it in post #2 you will have a working refrigerator.
