FIXED MFI2569YEM0 Troubleshooting help...Not making ice!
bassadict69
Benton, La
MFI2569YEM0
Is there something here or online showing me how to get to the parts and items I need to get to for troubleshooting. ie, how to remove covers, what to remove, etc.
Ice maker stopped making ice. I checked what I knew to check which is only basically that the ice maker hadn't jammed. All looks good best I can tell.
Can someone walk me through this? What/how to check next?
Is there ice in the ice maker tray now? But it won't cycle to dump it out?
If ice is in the ice maker tray now but won't dump it, then yes that would be a bad ice maker.
This is really for the damper behind the icemaker, but shows how the icemaker comes out...
[video=youtube;skImf4LBZSY]
Here's the ice maker for your model you can order:
WPW10300024 Icemaker
bassadict69
Benton, La
There are a few cubes of ice but it is mostly empty. I will have to try to get ice and see if it pushes the ice out.
I will check that tonight and also watch the video...thank you for the help!
bassadict69
Benton, La
Last night, I turned off the ice maker, left it off all night and turned it back on a few hours ago...it is now making ice again!
Excellent, glad to hear that, if it keeps stopping more and more and turning it off and on does not fix it, then it will need to be replaced.
