MFI2569YEM2 Issues With Programing My New Maytag Control Board
Yas
Trinidad and Tobago
MFI2569YEM2
I just changed the damaged Control Board in my Maytag fridge and I am trying to follow the leaflet instructions (hold lock door button 3 sec...) but to no avail. THE DISPLAY WILL NOT CHANGE FROM THE PE000
What could I be doing wrong, or is there another way to reset and program?
Make sure you have the program code from the model plate/tag then follow these steps exactly:
Press and hold the Door Alarm Keypad
Press and hold Freezer Temperature DOWN /- Keypad within 3 seconds.
Release the Door Alarm Keypad and wait 3 seconds
The control will display PE to indicate it's in programming mode.
Press the Freezer Temperature DOWN /- Keypad once more.
The control will display the current Program CODE.
If the Program CODE is correct, Press the Door Alarm Keypad for 3 seconds
Press the Refrigerator Temperature UP /+ Keypad or Refrigerator Temperature DOWN /- Keypad to change the digit value with each key press.
The decimal point indicates the selected digit. Press the Freezer Temperature UP /+ Keypad to select the next digit.
Once the desired Program CODE is entered, press and hold the Freezer Temperature DOWN /- Keypad until the Program CODE begins flashing
Press any key or press door alarm keypad for 3 seconds.
Yas
Trinidad and Tobago
Thank you for the response, this is exact instruction that i have been trying, but for some reason this doesn’t seem to be workinG.
At what point does it not work? In other words how far can you get with the steps above?
