- MFI2570FEZ05
- Maytag
- 6-10 years
My fridge's ice maker seems to be leaking and making ice clumps out of the ice in the tray. We have to take it out at least once a week and remove the clumps.
Reading around the forums, I saw many discussions regarding replacing the entire ice maker when this happens as parts wear out. Is this the best option?
I believe I have no issues with pressure and water comes out quickly from the water dispenser. Ice cubes are made fine, the water for ice is either leaking or overfilling.
Is this the correct part I need for my fridge if I should just replace?
click.linksynergy.com
Also discovered this Youtube video on replacing it. Really just looking for confirmation before I drop $250+
Thank you for your time!
Whirlpool WPW10300024 Ice Maker Assembly (AP6019087) - AppliancePartsPros.com
This part is an ice maker assembly for a refrigerator unit with a freezer. The ice maker assembly includes a complete ice maker and housing. A new ice maker assembly will be needed if it fails to make ice. If this part has gone bad, it may allow water to run into the ice bin causing the water to...
