dashriprok
- MFI2670XEM7
- Maytag
- 6-10 years
The ice dispenser pad (#4 in attached diagram) is wonky on a Maytag bottom-freezer refrigerator. Ice doesn't dispense unless you monkey around with the pad. Then if you get it going, it doesn't stop dispensing ice. It's like the microswitch behind the pad is sticky but I don't see any switch in the diagram How does the ice dispense pad come apart?
Next problem -- user interface doesn't work. It is lit up and each button acknowledges a touch with a beep but nothing changes. For instance you can't change from crushed to cubed or reset the filter or anything. The user interface is unlocked by holding the unlock button for 3 seconds but the icon shows that it's unlocked but again, it doesn't change position. Is this a user interface problem or a main computer problem?
