MFL70-D1211S Bad Resistor on Inverter Board f/ Midea Washer+Dryer
twscfltx
TEXAS
MFL70-D1211S
Hello,
I have a used Midea Washer Dryer combo in a closet on 120V in RV with surge protection and 20 Amp breaker. Error E64 started after we used it for three months. E64 means "Signal between Main PCB and Inverter PCB abnormal". I removed the inverter board and found a burned / blown out thermal resistor. I cannot tell the type or specs, so I'm not sure how to replace it. Midea said replacement parts were designed and made in China. Midea has replacement for $135. I found replacement part on Google search with a 820 Ohm resistor in place of the thermal resistor.
The resistor is in parallel between the relay and rectifier and in parallel with transformer and rectifier. I think the replacement resistor is a 4 band Grey/Red/Brown/Gold, but I do not know what the power requirements need to be. If it is 820 Ohms at 120V, then that would be .15 Amps and 18 Watts.
I would like to replace the resistor and add a fan to circulate air around the W/D.
Any suggestions?
Thank you,
Tyler
ridwanahmed
Atlanta, Georgia
I'm staring at E64 as well, and the thing is stuck with my clothes inside and an unlock icon (not letting me open the door, though!)
How do I remove the inverter board-- I figure an obvious physical check like above is a good place to start!
spritemast
atl
Hey Everyone,
I made an account here just to help out someone else with this issue with E64. The same resistor was blown on my inverter as well which is on the bottom portion of the machine. It is hidden close to the actual motor. The resistor used is actually a SL10 10003 Resistor. So you should confirm that the same resistor is blown and if you are able to you need to solder it onto the board. its like 60 cents to buy but $5 to ship but it should fix your problem. But please confirm first ur resistor or another part of the board is damaged. and just an FYI the CDW1510 by Edgestar is the same exact machine with the same codes so if you have another issue with the MFL70 please consult that error code guide
