MFT2771WEM1 Ice maker not dispensing ice
bbelk
Bothell, WA
MFT2771WEM1
The icemaker suddenly stopped dispensing ice. The water dispenser works just fine. I can see ice in the tray, but it just won't dispense it into the ice container.
Do you have a thermometer you can put inside the ice maker compartment? It has to be 16 degrees or lower for the ice maker to cycle that ice out into your ice container.
Also do you hear the ice maker fan running in the ice maker compartment?
If its 16 degrees or lower and the ice maker fan is running, then the problem would be the ice maker itself.
WPW10122559 Icemaker
