FIXED MFW9700SQ1 Maytag Washer - Tub Support Replacement?
Washingtons
USA
MFW9700SQ1
Model: MFW9700SQ1
Serial: CSU1121656
Symptoms: The tub started making knocking sounds when on spin cycles and the rim of the tub started rubbing the outer plastic barrel. It appeared that the drum was off balance somehow so as an avid DIY'r I tore it all the way down, removing the back belt wheel to expose the tub support backet. It has massive corrosion and sure enough it has deteriorated to the point where it just bent and broke apart as I applied pressure with my bare hands.
Here is a photo of the tub support and its' current condition.
Most of the big parts for this washer appear to be discontinued and not available. I am hoping to not have to replace the entire tub assembly as it would likely be more cost efficient to just replace the entire washer at that point. So the question is whether or not there is a replacement part for this bracket? I couldn't find anything but was hoping that the tub size/mounting dimensions are exactly the same on other models that still offer the tub support bracket.
Thankx for the update!
Best of luck with the new washer :)
jeff sr.
