MFX2571XEM0 Maytag Refrigerator Control Panel Not Responsive (Blank White Screen)
"BigAl"
U.S. of A.
MFX2571XEM0
See attachment. The control panel is a blank white screen. When I unplug the frig, it returns to normal for about 3-days and then back to blank white screen. Any fix for this?
-Al
Hi BigAl, Here's the parts diagram for your model:
You may want to check your electrical connectors to it, the electrical connections to it should be located under the upper door hinge cover, remove the electrical connectors and see if any of the metal pins are loose or backing out.
Then its possibly that display has gone flaky on you, and replacing it is over $500 for that part alone.
Its #2 here:
There are three #2's listed, the 1st is no longer available, the 2nd and 3rd are out-of-stock.
