MFX2571XEM2 Maytag Refrigerator low water dispensing
mu5ic92
Miami
MFX2571XEM2
Hello all hope to get some help regarding my maytag MFX2571XEM2 and an issue with water dispensing very very slow. After some research I went ahead and bought a water reservoir for replacement but when installing noticed that the water reservoir that was installed has a plastic end on it and connects into the water inlet valve WPW10270395 (attempting to attach an actual picture of the setup) which is located in the bottom back of the fridge.
The water reservoir replacement that I purchased is W10502642 but when you take off the red cap that comes at the end of the hose its a metal end. The only way that I see me being able to use this reservoir is to bypass the water inlet valve located in the lower back of the refrigerator completely which suspect isnt recommended since it must have some use. any input is much appreciated and I am happy to provide anymore information.
picture of where the plastic currently installed water reservoir connects to the water inlet valve.
Picture of purchased part
Ok, On this model you have 2 water valves, the smart valve is in the very back of your refrigerator, the water valve is inside the refrigerator section.
Here's the link to your service manual for your model: Dropbox - 8178777 R-109 2009 27_ French Door IDI.pdf
Start reading at page 4-10 to access your water valve inside the refrigerator section.
Here's the water valve inside the refrigerator section:
WP12956105 Valve
You can also watch this video to access it:
Then read the instructions that came with your new water reservoir replacement to install it.
mu5ic92
Miami
Thank you for the response. So for this issue im having is it still recommended to swap out the water reservoir? If so then the reservoir connects to both the internal valve and the smart valve mentioned before. The issue I have is that the new resovoir end cannot connect to the smart water valve as there is no metal end to hook it on to. The only way I see is connecting would be bypassing the smart water valve entirely.
Ok, I don't know the answer to that question, as I have not replaced this reservoir before on this model. And the service manual does not mention it either.
Hopefully another tech that has replaced this can shed some light on it for us.
Did you NOT get instructions with the new reservoir? It should've come with instructions!
