MGD9700SB0 Dryer will not start. Moisture sensor?
Jeff1028
Illinois
MGD9700SB0
Our dryer suddenly stopped working (Maytag model MGD9700SB0) the "sensing" light illuminates when the start button is pushed, but nothing happens. Here is what I have done so far:
Taped a piece of foil across the two metal strips located on the lint trap. When I pushed the start button the "wet" light illuminates (rather than "sensing"), but nothing happens.
I have replaced the following parts.
High limit thermostat # WP8573028
Thermostat internal bias switch # WP8577274
Thermal fuse # WP3392519
Also, what appears to be another fuse #WP3406653
I have confirmed that the lint trap (hard ductwork) is not plugged up.
Confirmed that the Radiant flame sensor is working with a multi-meter.
Any help that you can offer would be greatly appreciated. I'm beginning to suspect the motor.
Hi Jeff,
You had this listed as a GE, its a Maytag.:)
Did you ohm test your door switch?
We've had a few members report door switch problems.
You can ohm test it for continuity with your multimeter to make sure.
Here's that door switch for your model:
Door Switch WPW10318609
It shows on Page 4-6 in your repair manual I posted a link to below how to access it to check/change it. Make sure your dryer is unplugged!
Push the button in on the door switch with one meter probe on COM and the other meter probe on NO and see if it reads.(Should have continuity(0-1 ohm) between white wire and blue wire when switch is pushed in.)
The blue wire is NO and the white wire is COM on the door switch. Make sure your dryer stays unplugged when testing.
Here is the online repair manual for the Whirlpool Duet dryer: https://www.applianceblog.com/manuals/Duetdry.pdf
If the door switch ohm tests good, then ohm test the broken belt switch.
Check the broken belt switch for continuity.
279782 Broken Belt Switch Kit
There is a video in the broken belt switch part link that shows how to access/replace it.
If the door switch and broken belt switch test fine, then your control board is the culprit.
WP8546219 Control Board
Jeff1028
Illinois
Thank you so much for your reply! I just tested the door switch and I'm getting 0 ohms with the dryer door closed. Oddly, when I just push the button manually while checking resistance, I don't get anything, but with the door closed it seems to work.
Jeff1028
Illinois
So I just pulled the circuit board out and it apparently blew something. Do I have to buy a new board or are these repairable?
Yes Jeff, You'd need to buy the new control board, then you'll be back in business.:)
