- MGDB400VQ0
- Maytag
- 6-10 years
We had a brown-out in the area and afterwards my Maytag MGDB400VQ0 dryer would no longer run. After pushing the power button the estimated time remaining screen is blank. If I rotate the selection dial "---" then appears in the screen but the dryer still won't run. I can even use the +/- buttons to get the time to show 1 hr, and when I push start the time shows 59 but it still won't run. The drum light is working. The door switch is functional. I checked the thermal fuse and it is fine. I even got a replacement W10111621 control board but that didn't fix the issue. After entering the diagnostic mode I can get an error code C0 to come up but that is it.
In a search online it appears that someone else had the same issue and by replacing the WPW10336133 Control Board (user interface panel) it worked. I may give that a shot. If anyone else has other ideas I am all ears.
