MGR5755QDS Maytag gas Precision touch control 500 Oven not heating
melodypalmer
kamloops BC
MGR5755QDS
I have this Gas Maytag Range and the top burners all work fine but when I go to turn the oven on nothing happens. I get no power to the ignitors. Looking for what repair parts would be needed. Any help would be appreciated
You tested for 120 volts at the bake ignitor?
If yes and got 0 volts. Wiring between, bad gas safety valve or bad clock/control would be prime suspects from least to most common.
Oven-Control-Board-WP74009217-04730489.jpg Black Electronic Oven Control Board
If no, definitely test for 120 volts with a volt meter at the bake ignitor when the oven is set.
From the parts link I left above, a copy:
$232.93
Out of Stock
Expected Ship Date June 11
