MGR57650DS Maytag Range - Oven will not heat up.
korichm
Chicago
MGR57650DS
I have a Maytag Gas - Precision Touch Control 500 range that is not working properly. The display panel is working fine and the gas stove top lights and works perfectly. When I turned on the oven to preheat, the oven would not change from 100 degree temperature reading. When I felt inside the oven I felt no heat. The range is over ten years old. However the broiler and stove top still work. Please help.
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing orange, it should glow orange for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite within that 45-60 seconds, then your igniter glow bar is going bad causing this issue your having now.
Here's the oven igniter for your model(Video Included):
74007498 Oven Ignitor
