FIXED MH1170XSS0 Whirlpool microwave not working, no power.
ssruindia
Orlando
MH1170XSS0
The research so far has indicated that I may have to check the fuse for continuity and may be replace it if faulty. But the video of Whirlpool from RepairClinic does not match what we have on that model. So wondering if any body has a manual for that model of whirlpool or any other set of instructions to access fuse and/or replace it.
Unplug machine or remove power. Remove the bottom panel (10 screws). Remove the two screws from the panel on the bottom right front and you can access the fuse. If the fuse is open there's a good chance something caused it to open. Use a meter to check for a short between the power cord small plug terminal and the round ground terminal.
ssruindia
Orlando
Thank U very much for your reply. Your detailed instructions and other material I read on the site made me take a second look and this time I did find the fuse it was behind the front control pannel inside bottom compartment. Its facing down so it was not easy to spot. I replaced the fuse and microwave is working again. I have not fond any short which might have caused it to be open in the first place but will keep an eye on it. Thank U once again.
