MH2175XSQ0 Microwave works for about 2 seconds then shuts down
1der
Colorado
MH2175XSQ0
When I begin to heat something in the microwave, it stays on for about 2 seconds or so and then abruptly shuts off. It also emits a quick beeping sound: dee-dee-dee. Does anyone know what might be wrong?
I've not come across that problem before. The microwave hood combination is provided with a self-diagnostic routine that can be accessed through the touch keypad. To initiate this routine: Press and hold the OFF/CANCEL button while opening the door. While still holding the OFF/CANCEL button, unplug the microwave oven for 2 seconds, then plug it back in. Release the OFF/CANCEL button and close the door. All VFD segments will be lit to indicate the test mode has been entered. NOTE: If the OFF/CANCEL button is pressed during this diagnostic routine, you will exit the test mode. Here's the test panel chart:
1der
Colorado
Sorry it's been awhile since I wrote my first post. Here is what I found after doing the self-diagnostic routine: (1) After pressing the "Cook" button the display reads "Sensing", and then shows 443 which quickly turns to 444 and then finally stops at 445 (2) After pressing the key "3" the microwave does not turn on and instead emits 3 quick beeps and does this 3 times (3) After pressing the key "4" the display fluctuates between 060 and 061. I'm not sure what this all means, but obviously I am having issues. Do I need a whole new board?
I'll check if I still have it. This thread is 6 years old. Locate your tech sheet inside the microwave and that will have the same chart on it.
