FIXED MHW2000AWW Maytag washer - Motor & Motor Control Test
u118224
MI
MHW2000AWW
Maytag washer MHW2000AWW, washer fills with water then stops with no other noises. I suspect the motor control board. Where can I obtain a power test cord to perform the motor & motor control test, or can I just make my own?
Also, I am fairly sure this machine has not received the updated motor and board.
Yes, possibly the main control board/and or the motor control board, both have been failing massively on these early Neptune models.
Here's the service manual for your model:
Make your own cheater test cord.
u118224
MI
I did the motor control test and the motor did not run. I removed the motor control board and the fuse was blown. So, I know I will need a new motor control board. My question is, will I need a new motor to match the new board? I purchased the machine in March 1999, so the 10 year warranty is expired.
Thank you.
It comes as a motor conversion kit, so when you order the motor the motor control board comes with it.
Here's the motor conversion kit for your model(Installation Instructions and Video Included):
Drive Motor 12002039
u118224
MI
I purchased the updated replacement motor and motor control board. The machine works fine now.
Thank you.
Excellent, good job fixing it.:)
