MHW8200FC0 Maytag error F6E3
Vasi
Vancouver
I have a MHW8200FC0 with error F6E3. Went thru same steps with the same results and I'm about to buy a new MCU. I called Maytag customer support to order a new MCU and I was told that their tech needs to come to activate the new board, as the technician has to put a code in, to activate it.
Question: once the new MCU is installed and all wiring connected, is there a code to be punched in from UI (front pannel)? Do I have to get a technician to connect on programming port to do any setups? I thought it just need to turn on the washer once the new MCU is installed.
Thank you for your time and help!
