Micro turntable works sometimes and other times not
CincySparky
Cincinnati
FMCB115GC
Frigidaire
Frigidaire micro turntable will turn sometimes for a while and then sometimes will quit turning for a while. heard of anything like this before?
Make sure the plastic drive block ( under the glass ) is not cracked. It that is ok and the motor starts to turn the tray and then quits the turn table motor is then susupect and likely bad.
fmcb115gc
I can't find a parts breakdown for this, you will likely need to call a Frigidaire parts depot to check on the part.
Your welcome, if you get a chance let us know what happens with the repair.
