FIXED Microwave display is flashing 88:88
crudman
Pea Ridge, AR
FMV156DSB
Frigidaire
I replaced the primary interlock switch that was bad. Put it back together and now the display is flashing 88:88. :rolleyes: Please help
A copy:
• Before the microwave oven can be used, follow these procedures:
1. Plug in the microwave oven. Close the door. The microwave oven
display will then begin flashing
88:88.
2. Touch the Clear/Off pad. : will appear.
3. Set clock.
TO SET THE CLOCK
• Suppose you want to enter the correct time of day 12:30 (A.M.
or P.M.).
1. Touch Timer/Clock pad.
2. Enter time 1,2,3,0 and touch Timer/Clock pad again.
This is a 12 hour clock. If you attempt to enter an incorrect clock
time, ERROR will appear in the display. Touch the Clear/Off pad
and re-enter the time.
crudman
Pea Ridge, AR
Hi Jeff
Thank you for the reply, I tried pushing the key pad but there is no responce . I pushed the clear/off key but the number 88:88 just keep flashing. Question ! Do you think that I might have connected one of the wires incorrectly. Thank you Charl.
Kinda sounds like the key panal is undone or loose if pressing start/off/#'s/clear gets no response. Undo the ribbon and reseat it.
Just changing a switch normally won't hurt anything else unless we bump something in the process.....wiring the switch wrong could blow a fuse but -normally- will not effect other things. If all worked ok before your repair then definetly retrace your steps for sure!
crudman
Pea Ridge, AR
Thank you
Thank you Jeff:)
I will look at the ribbon and re-seat it. There are two sets of wires on the control unit that I am not sure about RY2, RY1 COM. N.O. I disconnected them to have better access I might have swapped those two. I'll let you know what I found.
Charl Rudman
